# False triggering with Automat
**URL:** <https://forum.dadamachines.com/t/false-triggering-with-automat/419>\
**Category:** FAQ / Support\
**Tags:** hardware\
**Created:** [April 10, 2020, 8:11pm UTC](https://forum.dadamachines.com/t/false-triggering-with-automat/419 "2020-04-10T20:11:09Z")\
**Posts on this page:** 1\
**Showing post:** 5
<div class="post-metadata">
**Author:** ![VincentP](https://forum.dadamachines.com/letter_avatar_proxy/v4/letter/v/f19dbf/32.png) [@VincentP](https://forum.dadamachines.com/u/VincentP)\
**Post date:** [April 20, 2020, 4:25pm UTC](https://forum.dadamachines.com/t/false-triggering-with-automat/419/5 "2020-04-20T16:25:57Z")
</div>
First, thanks for your quick reply, Johannes.
Second: I think it is my problem.
The problem seems to be the plastic screw-on shield on the cable connectors going to the solenoids. As Johannes noted, everything in my setup besides the automat is DIY. I used 20 gage solid core copper wire, which is stiff, it does not drape easily. These connectors are soldered to the copper wire and use a thread on plastic insulating cover. (Picture attached)
 ![image](https://forum.dadamachines.com/uploads/default/original/1X/7aaf2be714760446894e6f5b1c97435257b90ceb.jpeg)
When the plastic sleeve is screwed on tight, it apparently keeps the connector from seating properly in the automat, and the false triggers happen. If I loosen the sleeve, which lets the connector sit deeper in the automat, I don’t see the triggering problem.
I will try reshaping the plastic to see if that works. Eliminating them entirely is a bad idea, but there may be some other option.
There are more expensive, and bulkier, solder-less screw type connectors that have a longer metal barrel and do not seem to have the same problem.
For the record: I am using a 9v 1a power supply. I was using 5v solenoids, because that is what I had on hand. The recent attempt was with 12v solenoids, but still using the 9v 1a power supply.
Thanks,
Vincent
_[View the full topic](https://forum.dadamachines.com/t/false-triggering-with-automat/419)._
