Hellow my name is Benet! I have a Dadamachine that has been conected and working for some shows, but today seems is not working any more.
I try everything, to do the learning, but the midi in led is activated without the cable usb!
Is any way to make a reset total? The fuse inside is ok, pluged on 24V, but no response with the learnings?
Is any technical suport arround? Some one can fix it if i send it?
Maybe this info is helpful for others too. As you fixed the issue with doing a software update. Please remember for the future that you only use the LEARN Button for configuration. Don’t press the “RESET” Button. I will change the name of the “RESET” to “UPDATE” Button. As for RESET you need to unplug the Power Supply and USB Cable.
Do not press the RESET.
Hi Johannes,
Hellow my name is Luís! I have a Dadamachine that has been conected and working for some shows, but today seems is not working any more.
I think I need to make a new update, but the link you sugest is not working: https://dadamachines.com/getstarted/automat-software-update-process/
Can you please send me a new update and instructions link.
thank you!
Hi @extrapartes did you sort the issue? Sorry i did only see this now… please write me an email to support@dadamachines.com if you still need help.
Best, Johannes
