Hi,
am I correct that the bolts in the automat kit for the solenoids are not metric?
I need some more and some larger onces.
Cheers, Marc
Hi,
Cheers, Marc
Hi @Marcvv you mean the screws that directly go into the solenoids?
The thread for these is M3 > Metric.
So should be easy to aquire usually.
Best, Johannes
Hi Johannes,
Yes, directly in the solenoids.
If they are M3 metric, then yes I have those. They feel as if the thread is a little different and before I would force it I wanted to check. So thanks and I will use M3 then.
Marc
