Hi Dorian,
yes you can use electromagnets.
Best case they don’t draw more than 1.3A continuous at 24V.
The outputs on the automat are protected. So if you use a electromagnet that is TOO BIG nothing bad should happen. But the electromagnet might not work reliable if so.
