As I noted above, I found a local maker space with a laser cutter and was able to get a whole set of parts cut. So that’s the direction I recommend. I have access to two maker spaces and can possibly work something out with you, but it’s going to cost you more for my time, shipping, and I am not sure when I can get access to the cutters. There are also some online options that might be more cost effective.
Hi,
I recently found this page which has all the designs for 3d printing parts:
I then found a 3d printing company to print the three parts I required for the beaters (mallet-noid-craddle.stl, mallet-noid-linkage.stl and mallet-noid-plate.stl).
Worked a treat! The only problem is it can add up to be a bit expensive but definitely worth it to get the Dadamachine back up and running again.
Dan
School of Noise
