Hello everyone,
can I also drive servo`s with the automat ?
Best
Kai
Hi @Kailan yes you can. But not with the standard firmware. Means you need to write custom code yourself.
You can install the automat as a Arduino board with this board package: https://github.com/dadamachines/arduino-board-index
There are PWM pins for Servos inside of the automat. But you could also connect a PWM Port expander to use Servos on the Extension-Port of the automat.
Let me know if you have further questions.
O.k. thank you !!!
