Hello
is it possible to use the outputs to plug mosfets (or amplifiers of current) with separate supply of power to feed bigger actuators or electromagnets?
In case the answer is yes : does the automat itself need alimentation to send correct signals to the outputs or is the usb enough?
Is it possible to use 2 outputs in parallel (providing to assign the same midi note) to feed 1 bigger actuator?
Thanks
Giusto
hello giusto,
The thread below should shed light on your inquiry. I think a lot of this type of stuff has been discussed in previous posts. I’d recommend combing through the forum:
Hello, I’ve read everything in the website, but my question is more specific
1) is it possible to use the outputs to plug external mosfets with separate supply of power?
2) Is it possible to use 2 outputs in parallel?
I hope to receive a specific answer. Many thanks for your understanding
